I am going mad!!!!! I have been sent a PDF converted to paths and am trying to import it into Corel Draw. I keep getting told that the font is missing and that it will be converted to the nearest match. I thought if it was converted to paths there is no font?
I have downloaded the missing font, put it into my font folder. I can choose the font from the font list when I use it in a new document but does not show up in the list of substitute fonts when I try to import it.
Any ideas?
Importing PDF fonts missing
Re: Importing PDF fonts missing
- mrs maggot
have you actually installed the font, or just put it into your folder ? if you have just saved it into your fonts folder, and it is in its own zipped or unzipped folder it will not show up. open up font navigator (part of corel draw) and import it into there
spongerobinson
I dont use Corel, but I know in Illustrator if you outline the strokes/paths, then you don't require the font, so I'd imagine it's the same in Corel. My guess would be that the file wasn't properly outlined...perhaps the drawing/shapes were, but the font wasn't? When you open the file, albeit with substituted fonts, are you able to select and edit the text? If it's properly outlined, you shouldn't be able to do that.
Corel allows you to send too options or save options to have fonts with document when creating pdf files for print ready art work, seems they missed this option that's all
Directdesignsupplied.co.uk
Font maybe used elsewhere in the file. I use pstill. From pstill.com, sorts virtually all pdf issues.
Alan D
Alan D
