mugs , burn marks
twinx05
Re: mugs , burn marks
Post by twinx05 »
hi,
i bought a mug press last year , its had plenty of use.
I printed some mugs off last night and the paper & mugs had burn marks on one side.
The heat was on the normal setting i use, i am assuming this due to wear and on the heat blanket ?
Sorry to sound a bit thick but i haven't had the need to change the heat blanket before or come across the burning issue.
Any advice would be greatly appreciated .
Thanks in advance.
JMugs
Been thanked: 13 times
Post by JMugs »
In my experience the heat blanket is finished. Easy to change, but I would recommend buying from your press supplier as wiring can vary.
Janners
