Hi all
We want to experiment printing onto side and dinner plates. There are a couple of cheapy presses for plates and wondered if anyone has experience of them?
http://www.ebay.co.uk/itm/Digital-Plate ... 564a98e54e
http://www.monsterdoodles.co.uk/pixmax_ ... press.html
Olly
UKPrintedMugs
Plate Printing - Pixmax, Coralgraph or something else?
- UK Printed Mugs
Re: Plate Printing - Pixmax, Coralgraph or something else?
both are c#@£ that type of heating element will not print to the edge of the element, in fact you are lucky if you can get to within 1.5cm of the element edge.
- UK Printed Mugs
Thank you for your response. As someone clearly experienced in these presses are you able to recommend a better alternative though? Kind regards, Olly.
yes but it's no longer in production I believe......
HF2600 Plate Press
http://www.europa-leisure.com/HF2600-tec.html
A mere £878 from http://www.etcsupplies.co.uk/product_in ... b3778058f4
HF2600 Plate Press
3D Vacuum Print maybe?
- UK Printed Mugs
Hi. Apologies for delay but just back from vacation. 3D vacuum would work probably but only for those side plates. The machine does come with a plate sleeve if I recall. Food for thought
Thinking outside the box now. You know that you can now vacuum pack food and cook it in water baths. What about using the same method to vacuum a plate and the use an oven of some sort. Don't know what temp the vacuum bags will go to though.
Sent from my HTC One using Tapatalk
