After my issues with the vinyl peeling and wrinkling on my hoodies I am looking into a way of pressing the hoodie back without the pocket seam affecting the press. I have tried a google and the search bar here.
Does anyone know where I can by something similar to what is found on the bottom platen of a heat press. I can them put this between the garments when I press them.
Heat resistant foam
Re: Heat resistant foam
- mrs maggot
the pocket seam will not affect the press, but pads are available from yolo and also target, they are expensive for what they are, but useful for doing sleeves
http://www.yolo.co.uk/accessories-27-c.asp
Strange that because when I was doing the hoodies on one or two I pressed them with putting them over the platen and where the pocket was the vinyl lifted when removing the backing sheet.
Sent from my HTC One using Tapatalk
- mrs maggot
Now thats interesting, if you were pressing them as a double layer as it was, front and back under the press in one go, and they were lifting, so the press pressure was no where near tight enough, how much adjustment did you make to them when you pressed them over the platen - ie single layer ??
, i think you need to clamp your press down further, medium pressure on clothing, is quite different to medium on metal or sub stuff. I do 100's of hoodies a month and unless they will fit over the plate easily - ie adults larger sizes, i always press double - but adjust the press accordingly.
I didn't adjust the pressure. I just forgot to separate the back and front. I only knew I forgot when the press was harder to close. So in reality the pressure was higher but as I say along the line of the seam as I pulled off the backing paper it lifted in areas. Maybe it was just coincidence. Normally I use a medium pressure. I have an unnamed press but it has a big black screw sticking out of the top and I can adjust pressure from there. On a prepress when I lift the press you can see the whole platen area has pressed the hoodie. It looks a slightly lighter colour.
Hi Quins
I think you need to get yourself on a textile course
Please do not think I am being patronising there, I wish I could go on one but can not justify it with the numbers I am doing which are all t-shirts.
Grafitype run a course normally a couple of times a year in conjunction with Siser (who sell really decent vinyls). The course is free and I would recommend you call Grafitype asking them when the next course is and also ask them for a sample pack of Siser films. I think it would be really useful for you.
From what I have heard its a really good course (one 1 day I think) and you come away with buckets of knowledge.
Doesn't help you right now, but it might in the future pal.
No offense taken at all. I think I started to run before I could walk. Never done a large run before with various sizes only done the odd one or two for people.
Users browsing this forum: Majestic-12 [Bot] and 1 guest
