I have 450 shoulder bags that I have no need for.
They are the sort of bag you get at a promotional trade show.
See pictures, dimension are
CLOSED: 300mm x 375mm with a 10cm Gusset
I have successfully heat pressed vinyl to these bags before. They key factor is temperature and ideally you need something around the 125 degree mark. I used TMT 123 Flex and Soldark when I did them.
Looking for the following:
50 @ 60p each
100 @ 50p each
200 @ 40p each
450 @ 35p each
Post is £6.00 regardless of quantity (if you take the lot I will do free postage)
Sorry, I can not do lower quantities, its not worth it.
Courier Shoulder Bags
Re: Courier Shoulder Bags
- vB_ID:3580
- IMG_1162.jpg (96.66 KiB) Viewed 5 times
- vB_ID:3581
- IMG_1163.jpg (95.52 KiB) Viewed 5 times
