3d press dropping temperature then taking ages to get back up.
3D Sublimation
Kyebie
Re: 3d press dropping temperature then taking ages to get back up.
Post by Kyebie »
Hi
I have a 3d vacuum heat press from coralgraph. when in use the temperature can drop from 195C to 168C then it hoovers at that temperature for a while before a slow gradual rise back up to the set temperature. Should this happen when in use.... its bugging me.:mad:
any help would be great.
Thank you all.
Ucase Ltd
Post by Ucase Ltd »
Is this the ST3042?
If so it may be the temp sensor needs replacing. Not sure if there are any uk stockists for these.
