printable vinyl for skins - ecoselvent/solvent
Re: printable vinyl for skins - ecoselvent/solvent
Hi guys,
Any recommendation for some nice and thick vinyl to print laptop skins? I know there is some strong vinyl with grey glue but not sure if this one is ok and if its removable.
any ideas?
I appreciate any help.
any ideas?
Do you have the cut files Paul? I imagine these have to be very accurate?
Vinyl is bigger problem then templates buddy
i did one for my macbook months ago and it was perfect fit
Either MPD from Metamark (100 micron) or KPMF Air Release (from MDP) are both pretty good.
I am currently looking at some Fuji media and they have one which is a clear film, adhesive back that leaves no residue and can be re positioned as many times as you want. Have seen a few sheets and was thinking that may be pretty good for your needs.
Thanks simon. Will look in to them. not sure about clear stuff thou
The clear stuff works well with black designs on Apple laptops, or if like me, you can print white and metallic
I cant
and i prefer the white stuff...
cant find descent stuff for this job :/
still looking for some thick vinyl.
I remember i had laptop skin about 7y a go and it was as thick as 1mm or maybe little bit less. it must be available somewhere...
its not removable. but thanks
i think i found what i wanted.
