Re: Graphtec cutter won't cut exact size
Posted: 20 Apr 2015, 11:52
by epstnb
Been using the Graphtec with corel x5 for a while now and never had an issue with it.
Today though i needed to cut something exactly 480mm high. and cutting master 2 shows it is 484mm high.
I have checked the step size is the same in both cutting master and the Graphtec (CE 5000-60) its the same (ie 0.100)
Job size is set to 100% and proportional.
Am i missing a setting somewhere ?
thanks in advance
nb
Posted: 20 Apr 2015, 11:57
Is this set to be proportional to the width of the vinyl? If so, are you sure there is 480mm available to the cutter?
Posted: 20 Apr 2015, 12:13
by epstnb
hi,
the vinyl is 500mm wide, and polling the size from the cutter shows i have 483mm available to cut in
The size in corel draw is 480mm..
perplexed !
update fixed it .. under advanced in cutting master there is a setting for panel margin (for weed lines) it was affecting the size even though i have weed lines turned off.
anyway that sorted it !
Posted: 20 Apr 2015, 12:14
I had a very similar issue but luckily I could turn the designs I had to fit in better. Does it attempt to cut and miss part of the design or just not try at all?
Posted: 20 Apr 2015, 12:42
by epstnb
Thanks Justin, i wasn't able to rotate the designs but managed to sort it out thankfully (updated in post above)
Cheers
Posted: 20 Apr 2015, 12:44
Nice one
