Liuye sc 631 cutter any good.??
Ravisteam
Re: Liuye sc 631 cutter any good.??
Post by Ravisteam »
I ve got a new Liyu TC631 cutter for 150 pounds .is it a good deal ??..can this cutter use for T shirt vinyl and is it sharp and quality ..??. Can you do contour cutting ..??.thanks .
Disky
Post by Disky »
just bought one myself, it is only a cutter, i doesnt print.
i have used it for t-shirt vinyl using sign blaser and signcut pro with no problem,
Ravisteam
Post by Ravisteam »
Disky;100187 wrote:just bought one myself, it is only a cutter, i doesnt print.
Thanks for your reply .Sorry print can cut I meant contour cutting ..!!..Ill start operating it from tomorrow any issue would you mind if I pm you .Thanks
Disky
Post by Disky »
I had an issue with the blade carrier, it came off the rails in transit, a bit of pushing and it was back in.. Quite noisy, but I'm just very new to it, I found that a cheap roll of wallpaper lining paper was a good investment as I can change to pen and check everything before I cut it...
that at saved me a fair bit of vinyl as I kept forgetting to reverse the image for t shirts lol
