Hi guys
I've been asked if I can do glittery text on a mug, what software, if any, can achieve this?
Or, would I be better using vinyl and if so, will garment vinyl work?
Glittery text on a mug
- Has thanked: 11 times
- Been thanked: 9 times
Re: Glittery text on a mug
I've seen sign vinyl on a mug before but it doesn't last too long, better as a novelty unless carefully hand washed.
You won't get a glittery print with the sublimation inks, unless you can get them to accept a glittery type text or design? Maybe using stars/twinkles etc?!
That's what I thought Justin, thanks.
Will need to have a play with the various software I have and see what can be done, if anything.
- purpledragon
you can get some pretty stunning effects with photoshop using the lighting filters
Excellent, thanks, will go have a play with that, it's on one of our machines, somewherepurpledragon wrote:you can get some pretty stunning effects with photoshop using the lighting filters
