Which Mug Press Should I Buy?
Re: Which Mug Press Should I Buy?
My mug press is getting old and wants to retire! Its about 6 years old so I guess it has the right. Anyone out there have idea which one I should be looking at?
All depends on the budget you have really
You could do worse than check out some of the presses BMS sell. The Xpres one is supposed to be very good, bit pricier. George Knight DK3 is the rolls royce but will set you back £700+ I would think.
Also depends on the amount of mugs going through the press as to what durability you need. May also be worth considering an oven with wraps and/or the press.
