Would anyone know if it is possible to use Digicoat spray on let's say a tablet case using the adhesion promoter ?
Or would this not be possible due it not being a solid surface.
Thanks.
DigiCoat coating question
Re: DigiCoat coating question
Tablet case would need to be up to the temperatures required. Also, a light colour is required otherwise you will have to use the white spray as well. Might need a jig also depending on design of case.
Was thinking to cook it rather than putting in the oven, maybe put under the heat press without any contact so that the plastic holders would not melt.
If it's a faux leather or leather type case then maybe they could hold up to the temps needed.
The other thing is, would the spray crack under pressure once cured?
