ricoh aficio 3110 dn
tiamaria
Re: ricoh aficio 3110 dn
Post by tiamaria »
hi all would any of you be able to help me out with a driver disc for my ricoh printer i bought a full print set up last week but i want to change the computer that came with it for my own ,but when i plugged my printer in to my new computer on friday it searched for a driver but could not find one ,i have tried to download it from ricoh but every time there is no setup.exe in there to install ,many thanks
Just google Ricoh sg3110 driver and go to the ricoh website. Download the file for your version of windows (the Raster file), unzip it and run the installation file.
tiamaria
Post by tiamaria »
hi bms ,thank you for the reply ,i have tried that but there dont appear to be an installation file in there ,tried it several times on friday ,thank you you for the info i will try again this morning
Ask_Alan
Post by Ask_Alan »
If you do not have the CD that comes with the printer then download from Ricoh.co.uk get the RCPS raster driver version.
Download the zip (called Z68195LF.exe for windows 7*64) then run it. It will offer to extract to "c:\temp\z68195Lf"
open this folder and run the "RP_SETUP64.exe" follow instructions and connect the printer when asked.
The actual Z number will vary with the version of Windows selected.
For 32bit setups RP_SETUP.exe is I think the name
Alan
tiamaria
Post by tiamaria »
Ask_Alan;98879 wrote:If you do not have the CD that comes with the printer then download from Ricoh.co.uk get the RCPS raster driver version.
Alan
cheers alan will give it a go later thank you for your help appreciate it
