Generic heat press, large press area, works well, timer not working - this could be fixed with magnet. never bothered me, as was mainly used with 123 flex.
rubber in good order, and top heat plate is clean and in good condition
you can arrange own courier to collect, as you can imagine its heavy, or collect from Kettering Northants £100 ovno
please note the brown tape marks, are where i taped on a silicone sheet, and i will clean them off
Large Heat Press 50 x 40
- mrs maggot
Re: Large Heat Press 50 x 40
- vB_ID:3341
- heatpress 2.jpg (77.45 KiB) Viewed 4 times
- vB_ID:3340
- heatpress 1.jpg (86.89 KiB) Viewed 4 times
