Brother DCP-J140W - Does not seem to print black ink
Re: Brother DCP-J140W - Does not seem to print black ink
"something something full"
very good description of the problem
waste ink tank full?
malfunction
Possibly an airlock if it was working ok before, you could try taking the refill bung out to let air in, if that doesn't work get a syringe (without the needle) and put the end over the refill hole, put your finger over the breather hole and gently squeeze the syringe, you should feel a bit of pressure, then do an head clean.
No responsibility taken if you mess things up !!
