equiptment reccomendations?
soulclaimed
Re: equiptment reccomendations?
Hi I have saved some money that I want to put to good use, I have £600 to spend. I currently have an epson 4800 for inkjet transfers and canvas. A large clam heat press from bms a Chinese swing away heat press liyu sc631e vinyl cutter and ricoh 3110dn and a stand alone mug press from signz world what within my budget should I get next will there be anything at printwear and promotion within this budget worth waiting for?
Printwear and Promotion is a week away, without a shadow of a doubt you should and see what is out there.
There is nothing you need to buy this week that can not wait (otherwise you would buy it without our opinion
soulclaimed
I nearly picked up another 4800 for 220 but someone beat me to it I was going to convert to sublimation but have also been thinking of sunangel stuff but I hear its not great so ive held on so far I also want a bigger printer but cant pick up because I don't drive
Dave271069
sunangel printer seems ok in my opinion, it does what it says on the tin, which is print white laser papers, it could be a good buy for the right person if work demands it but only you will know.
like socialgiraffe says best wait for P and P and see what floats your boat, you can also see the sun angel stand and decide for yourself
Got a pair of sunangels here and going fine.... darn sight cheaper than a 711
soulclaimed
What's the washability like and price also can you buy papers in smaller quantities?
Cheaper printers because they are not as good as the 711 engines. The printing is also considerably more expensive. A proper OKI white will work out a lot cheaper long term, plus they are more versatile.ArferMo;97623 wrote:Got a pair of sunangels here and going fine.... darn sight cheaper than a 711
Been all through the costs on the other thread..... not going there again suffice to say not everyone wants to splash out the cost of a 711 when you can get going and test the waters at a fraction of the cost.
Papers are available in 10's or 20's I believe plus there was a huge price drop a few weeks back.
soulclaimed
I was more talking about initial outlay not ongoing ill takes look at their stand
I 100% agree with that comment, but your statement inferred that it is cheaper and it isn't, in fact it is considerably more expensive, even Sun Angel by their lack of response to direct questions presumably admit that.Been all through the costs on the other thread..... not going there again suffice to say not everyone wants to splash out the cost of a 711 when you can get going and test the waters at a fraction of the cost.
Its a bit like using different paper, you and I probably agree that Trupix is the best paper around. It is more expensive than the cheaper unbranded stuff sold. But it is also better because it produces better results and less failures. just saying
Soulclaimed, the outlay is cheaper than the cost of a 711, but do your maths and figure out exactly before purchasing anything. The difference is not as much as you think.
