Badges temps/Duration?
petedale
Re: Badges temps/Duration?
Post by petedale »
Hi All :biggrin:
Still a novice, Only found out today that the sub paper has a shiny & a dull side :rolleyes: ....
I am about to try my hand at printing some aluminium badges, 33mm x 21mm inserts,
Any idea's anyone on temp & Duration to press them at?
I have a flat swing arm press.
Thanks all in advance.
ArferMo
Post by ArferMo »
50-55 seconds at 190º centigrade with medium pressure. I put paper on the bottom aluminium on top so that heat comes through the badge to the paper.
petedale
Post by petedale »
Thank you very much my mate, appreciated, i'll give it a go now, :biggrin:
petedale
Post by petedale »
Perfect Results......... Thank You
