Tray With Beanbag Base
whitesquizzel
Re: Tray With Beanbag Base
Post by whitesquizzel »
Hi anyone know of anywhere that sells sublimation blanks of the trays you can get with a bean bag base ?
Also for printing of trays and other larger items in general is it possible to do these on a 15x15 press - say by pressing one side first and then the other or is the only way to do these to get a larger heat press?
I wouldn't recommend a 2 stage press unless you have a white (or blank) area where the join is. You're likely to get a join in the print (or an overlap) which will be obvious once printed.
Users browsing this forum: Baidu [Spider] and 5 guests
