Problem with colour on photoshop elements 12
Re: Problem with colour on photoshop elements 12
As you can see I am having problem with colours. In the photo it shows the image I wanted on iPad but insert on to photoshop elements 12 (middle) middle pink has gone blueish and third was my print out. I know the print won't be as good because of the colours you can print, but why is photoshop the colour not the same, is it a easy fix I don't know much on photoshop,
- vB_ID:3214
- image.jpg (83.18 KiB) Viewed 29 times
The colours in Photoshop look correct and it is most likely a colour temperature issue. The door is white with the main light source being daylight. The baby is lit by a multicoloured TV, so those are the colours being displayed.
The ipad photo is under exposed, whereas Photoshop has probably auto-corrected the exposure hence the bright colours.
Sorry the picture doesn't show it right, (my fault) this is the photo I was trying to insert into photoshop.
- vB_ID:3216
- image.jpg (92.88 KiB) Viewed 29 times
you need to brighten your screen up to similar level as your pc screen and then compare.
Also print it on the insert and don't judge the paper print. Paper will always look different
Thanks guys, just checked price, ohhhh, for datacolour spyder. am I doing something wrong on photoshop as I have printed stuff, and images have been ok, but this one is strange, is it because the pink is a colour it can't process properly? I'm out of my comfort zone on computers with this,
Sublimation prints straight off the printer will look nothing like the sublimated colours...... The colour changes when heated to 180C.
Re the Spyder... you really need the Spyder4elite to do a good job on multiple screens/phones/tablet's.
That reminds me, think I'll do a re-run now.
I will try it as it's all trial and error for me, first time at fridge magnet, in the second photo I put on, that's clear it was taken on iPad and then I emailed to myself and opened in outlook and copied onto computer, if I open in windows gallery it's looks the same as photoshop, I have to do it this way because my stuff isn't synced through iTunes to this computer,
