Square chromaluxe panels between 15cm and 29cm square in clear finish (NOT WHITE)
Help in finding new products.
jonw
Re: Square chromaluxe panels between 15cm and 29cm square in clear finish (NOT WHITE)
Post by jonw »
Hi all,
Like the title says I'm trying to source some square chromaluxe panels not 15cm square and not 29cm square - but will consider any sizes in between. Ideal would be around 25cm (10 inch). Must be in clear finish (NOT WHITE).
Have tried Xpres/Novachrome...
Many thanks!!
If Xpres don't carry it, then chances are it isn't available as standard, and you'd have to buy a bigger size and chop it down - do you have a metal guillotine that can cut 1mm thich metal cleanly, or are you good with a saw?
JMugs
Has thanked: 11 times
Been thanked: 10 times
Post by JMugs »
Altarnun.....and you have internet....is that allowed, it'll spoil the village! The river will rise and all will be flooded.
Anyway back on track....BMS used to cut to size and they carry some unisub products. Might be an option there.
Worth speaking to Nicci at sublimetals as well :-)
