Mug Heat Press for backup
daddykev
Re: Mug Heat Press for backup
Post by daddykev »
Mug Heat Press for backup what you thought about this one?
do you use one?
have you got one for backup?
:confused:
http://www.ebay.co.uk/itm/UKPress-MUG-H ... 2516.l5255
Thank you for your help in advance.
Simong12
Post by Simong12 »
I'm just a hobbyist in mugs, I have similar and I've done ok with one but only done 36 mugs, all depends if your doing it as business or hobby I think, I don't have much experience but I thought I would reply to question.
So far touch wood it's been fine,
daddykev
Post by daddykev »
thanks Simong. its going to be as a business back up.
rossdv8
Post by rossdv8 »
I use something similar and recently bought a spare standard heat element/pad. I think if I need a backup I would try for an almost identical press to the one I have because I already discovered my old press and the one similar to your picture work completely differently on times and pressures.
I actually prefer the cheap ebay press to the more expensive original press, but I wasted some mugs learning the difference.
We use four presses like this to produce all our mugs, and we'll be looking to buy more later this month
Post by GoonerGary »
I have three of the older versions of this press and I have that exact press in a box waiting to be opened...when I start work!
I have back up machines but only because I have replaced machines along the years. If I was starting out now I would not purchase a back up, but instead leave the money in my business account. Should the primary machine malfunction I can always purchase a new machine which would be with me the following day, but then I would never purchase a machine from Ebay, I know there are good as well as bad suppliers on there, but its too much of a risk to my business personally speaking.
Yeah, we don't have backup presses, we just have presses that get used, if one goes down, we still have the other presses that we use, just means we make a few less mugs per hour.
JMugs
Has thanked: 11 times
Been thanked: 10 times
Post by JMugs »
I am with Pisquee.
I run 2 adkins and 2 DF1's, if one goes down I print slower until another arrives the following day.
daddykev
Post by daddykev »
Thanks all
Users browsing this forum: Amazon [Bot], Bing [Bot] and 1 guest
