help with time and temps on new setup
dan...
Re: help with time and temps on new setup
Post by dan... »
Hey guys
I'm back sublimating mugs, i've got a new setup and playing about with it now but it's not coming out right.
Here's my setup
Epson 1500w A3 Printer
PIXMAX Mug Press
Xpress sublimation Paper
{third party ink name removed} Sublimation Ink
Now i'm confused about temp, time and pressure, everyone is different and i'm guessing this is due to the presses used but an indication would be nice.
Also, is there a template / set of colours to print that once you get them right then you know the time, temp and pressure?
Back obviously will go brown if it's pressed too long, so should I just stick to printing a black mug for the moment?
I've also put my temperature reader on the press and the temp is not consistent throughout the element, the ends appear to be lower than the middle.
My indication is that the mug needs to get to 190ºc in order for the ink to transfer and the time set to 180seconds, but my press has an idle temp and a actual temp.
So if I put he mug in when the idle is 190ºc, it will take time for the mug to reach 190ºc, then do you count the 180 seconds from then? or from putting the mug in
Post by GoonerGary »
I try to avoid presses which have idle temperatures, but can you just set it to the main temperature? I have three identical cheap presses and they are all set at different time/ temps. So one is 187 degrees/ 195 secs and one of the others is about 170 degrees 175 seconds.
To find the right time, I will print off some large black text and find the minimum time which will not cause any smudging. Check it a few minutes after taking it out of the press. A design which might have a large solid black would be given extra time to suit that design. Start with 180/ 180 and let the heat blanket gently curl round the edge of the mug. It takes a few mugs to get the perfect set up.
