Heat press?
Canongirl
Re: Heat press?
Post by Canongirl »
Looking for a heat press for a new venture, I seen the df30 from bms, can anyone recommend? I live in east scotland so any info on local sellers would be good too
many thanks
Re: Heat press?
Hi. Well we have a super cheapy flat press for doing coasters which seems to be perfect in use. Maintains temperature and not a problem doing 6 coasters in 60 seconds. We bought it for £114 (b grade although only has a scratch) but I see price has gone up and may be out of stock. http://www.ebay.co.uk/itm/SWING-AWAY-HE ... 1315229711
BMS I can certainly recommend as a company as their support is very good. Olly
Re: Heat press?
http://www.coralgraph.com/heat-press/fl ... al-version
These are cracking little presses for the money, I sometimes use for smaller items. Of course, you get what you pay for but this could be enough to get you started :-) If it's big enough.
Canongirl
Re: Heat press?
Post by Canongirl »
Thanks guys,
justin the one you linked to, is that the £75 one at 23x30cm? Is the temp even all over the plate?
Thanks again
Re: Heat press?
Yes it is. Temp is certainly even on mine. This can be an issue on cheaper presses due to the element layout but I know a few members using these with no apparent issues.
Re: Heat press?
I had this very same model from this same supplier and my temp was great. I miss this little machine.
Bob @ Prestige
Re: Heat press?
Post by Bob @ Prestige »
Can I just jump in and say thanks for the replies and info, as I'm also looking for a heat press and the info along with sound recommendation is a big help
Bob
