E shop from scratch knowing nothing!
Any OS, software in here.
Re: E shop from scratch knowing nothing!
JMugs;47445 wrote:Courtesy of our man who can "Steve" we are a bit further forward.
The emails still don't get to my AOL address even though I have checked all Spam filters, and all things that may be blocked. However I can access and reply to them all in CPanel.
So we have established that "opencart" is doing its bit, the server appears to be doing its bit, what happens with it geting to my AOL address is anybodies guess.
Steve switched the email address to his own and it works fine, put it back to my AOL address, and ....... nothing.
The odd thing is that and order gets through, a "contact us" enquiry does not.
Strange.
Janners
Why not set yourself up with a gmail or hotmail account to test - you can always forward to your AOL account, but it sounds like AOL is preventing the email coming through for some reason.
JMugs
Has thanked: 10 times
Been thanked: 10 times
Post by JMugs »
Sounds like a sensible idea.
JMugs
Post by JMugs »
Now I have opened a hotmail account, all I have to do is work out how to send the emails to it from "opencart".
Tonight it appears the "Contact us" emails aren't even arrivng in Cpanel.
Either I am very good at screwing all this up, or "opencart" is hit and miss. I assume other people on here use "Opencart" but no comments like "Also had problems" or "It was simple".
It all appears to be simple, I just can not get it to work.
I'm going to bed.
janners
bigj2552
Post by bigj2552 »
JMugs;47512 wrote:Now I have opened a hotmail account, all I have to do is work out how to send the emails to it from "opencart".
I'm going to bed.
janners
its only simple once you learn how to use/alter it ! - i had a right royal pain with it at the very begining.
DONT give up - you will get to grips with it -HONEST :wink:
time and patience are your best friends -and er....google/youtube/on here/opencart forum ect
smitch6
Post by smitch6 »
if the emails aren't in the cpanel then you've prob entered the email address wrong
it anything doesn't work always check everything in detail to make sure it's exact
it's so easy to put a , instead of a .
JSR
Post by JSR »
I use OpenCart and the email system works just fine.
However, I wouldn't use either AOL or any of the "free" email services if they paid me. They are all far too quick to consider something as spam, and delete it or otherwise drop it from getting through to them. Whenever I see a customer sign up with a hotmail, gmail, or AOL email address, I groan because I know it's going to be an absolute hassle to contact them if there's a need to.
For myself, I just use the email addresses I get with my registered domains. As they're on the same server, no external party can get in the way to block/drop them.
If you're using a WHM/cPanel server and you think the emails are being dropped somewhere between OpenCart and the domain's email account, you can look into the server logs to find out what's going on (or get your host to look into them).
JMugs
Post by JMugs »
JSR;47527 wrote:For myself, I just use the email addresses I get with my registered domains. As they're on the same server, no external party can get in the way to block/drop them.
Now that sounds like the most obvious thing to do but can I do that without going into cpanel?
JSR
Post by JSR »
JMugs;47528 wrote:Now that sounds like the most obvious thing to do but can I do that without going into cpanel?
I don't know what your set-up is, so I can't really advise.
I use WHM/cPanel all the time to set up accounts. Email accounts I set-up in cPanel are regular POP3 accounts which I retrieve mail from on my computers/phone/iPad. I set my mail software to leave the mail on the server for three days (so that it's available to my other devices, and so that I can log-in to webmail in the event that it becomes necessary).
JMugs
Post by JMugs »
Thanks JSR
Computers confuse me.
I can get into Cpanel from the computer in my office at home, however if I try from the netbook, or my office at work I can't. It say the "IP address has changed". Is this right?
I am fairly convinced that all this confusion is me being dumb.
Janners
JSR
Post by JSR »
I don't know why a change of IP address would be an issue. You should just be able to log-in afresh.
Sometimes too many failed login attempts will make the server block the IP address for security reasons. That might be what's happening here, but it's impossible for me to tell.
None of us were born with this knowledge. If you think of yourself as "being dumb" just remember that we were all "being dumb" once upon a time. You're not "being dumb" - you're just not familiar with the system yet. You'll get there.
Remember that everything that goes wrong today is one new piece of knowledge you didn't have before. Once you've got that knowledge, it won't go wrong again in the future because you'll know the solution instantly. Then you'll be like us... (although I'm not sure if that's a particularly appetising recommendation! :wink:).
