FlexiSign 10 Black Lines over everything.
Re: FlexiSign 10 Black Lines over everything.
Use lifting paper to create the sticker ,then place on tshirt,same as we do for signs
Directdesignsupplied.co.uk
Yes, FlexiStarter is about £70 I think - I will find the link.
Yes, £67 BUT this version is only for the Liyu: Ear.
Nik... the software itself is not made for individual makes of cutter rather it has different drivers in its software to run different makes of cutters. So basically the software should function on the majority of cutters out there if you can find the driver in the software. As Signzworld is a distributor/wholesaler for these products, they can sell well below the normal retail price which is more up around the £100 mark..... so this is a good deal but not specifically for Liyu only....... it will do for most cutters as long as the driver is there. I think if you check their website.. SAi.com....... there is a download of all the compatible cutters and driver list.
