flex aint happening
gorgall2
Re: flex aint happening
Post by gorgall2 »
An easy way to tell which side of your vinyl is which is to cut a corner with a craft knife. Can't understand why you are having to press hard with your sign vinyl, what type of squeegee are you using?
hidehi
Post by hidehi »
bigj2552;50423 wrote:why are they putting updated software out that is obviously faulty somewhere ????
No idea, but methinks it was released too soon as it wasn't tested enough...there'll probably be another update soon to patch the bugs!
bigj2552
Post by bigj2552 »
gorgall2;50424 wrote:An easy way to tell which side of your vinyl is which is to cut a corner with a craft knife. Can't understand why you are having to press hard with your sign vinyl, what type of squeegee are you using?
the flex vinyl i have doesnt have a backing to do that with bud.
and Teflon Squeegee from here - http://www.mdpsupplies.co.uk/cameotools.asp
bigj2552
Post by bigj2552 »
another thing - why do you have to mirror cut ?
i just cut this flex vinyl without mirror - cut fine and printed fine on shirt !!
so why mirror ?.......just cut on the side that your gonna be looking at - weed it off and straight onto garment...
so what im i missing ?
reason i ask is -
if i want to mirror cut on the BMS flex, i have to cut shiny side up,and mirror.....usually its dull side up and mirror for other flex :confused:
hidehi
Post by hidehi »
You can't cut shiny side up, it has to be the matt side. The shiny side is the backing paper (which you don't want to cut) and the matt is what you transfer to the clothing. The reason you have to mirror cut is because you turn it upside down so the shiny side is facing upwards and the flex design is looking back at you the right way round! Make sense?
WorthDoingRight
Post by WorthDoingRight »
Sign vinyl is cut vinyl side up and backing paper down. If you are going to stick it on a wall or sign etc then you cut normal way around. If you are going to stick it on say a door in the inside to view from outside the door then you cut mirrored.
T-shirt vinyl will depend on type. The current material I use is a clear top coat with the flex on the bottom. So you have to cut it upside down (e.g. shiny side down) and mirrored - so when you turn it back over you have a clear coat with your flex underneath that you then press and peel the clear layer off. I suspect that there must be t-shirt vinyl that you do cut with vinyl up but that would make me think you would have difficulty keeping any design laid out correctly unless you then have to use mylar transfer tape to move it?
On a positive note my sticky backed flock has arrived and I believe my rhinestones (although the mylar transfer tape has not as yet). So maybe do a rhinestone flock template later to see.
bigj2552
Post by bigj2552 »
@hidihi - yep, makes sense.....
@worth - lol, yeh, let's see the flock flying - or will it be "flying to flock" :tongue:.
thats my next encounter - rhinestone flock templates....
will see how you go first :wink:
what you using software wise to create your rhinestone templates ?
WorthDoingRight
@bigj2552 I am going to try the simplest method that will not cost me which is to place 3.3mm circles on a path in coreldraw. I have played around with this technique and it seems to work fine. There is an addon for coreldraw I think called rStones (or similar) that cost around $50 that looks interesting also.
Must admit I only ordered my rhinestones and a single stone heat wand from Hong Kong on the 27th July and they both arrived today. Typically the mylar transfer paper ordered from a UK supplier has yet to arrive although they say they have posted it.
Rstone is cool :-)
gorgall2
Post by gorgall2 »
I use the cheap squeegees at the top of the page and don't have to press hard.
