Re: Right - that's it, I have OFFICIAL had enough of this epson B1100
Posted: 28 Sep 2012, 19:58
You could try cleaning fluid instead of meths.
Not Just Sublimation
https://dyesubforum.co.uk/
This is the stuff I'm using at the moment:gorgall2;54841 wrote:You could try cleaning fluid instead of meths.
and where would the air bubble be Paul? (like I said the printer has been stripped and I'm not running a ciss systemPaul;55051 wrote:this is more likely air bubble(
I can't wait for that day Paul - I need it fixed and not 'wait' for the problem to resolve itself - and it won't fix itself as I can't use it!Paul;55051 wrote:it will go one day....
Thing is, 2 printers with exactly the same problem ................ that's why (as suggested) I thought the ink was the problem?Paul;55053 wrote:maybe onfe the nozzles are damaged? if so there is no "fix" for that as far as i know...
i suspect they'll say... 'Take it to an authorised service centre for them to have a look at' or they will offer to replace it (but with what... as the B1100 has been discontinued...).AdamB;55055 wrote:Thing is, 2 printers with exactly the same problem ................ that's why (as suggested) I thought the ink was the problem?
I'll see what Epson say tomorrow - should be interesting!
I know Martin - it's annoying but I have the nearest service centres details just in case.bms;55057 wrote:i suspect they'll say... 'Take it to an authorised service centre for them to have a look at' or they will offer to replace it (but with what... as the B1100 has been discontinued...).
