flushing out my brother...
bigj2552
Re: flushing out my brother...
Post by bigj2552 »
not having a good time here at all bud....
between hosts and bloody printers :rolleyes:
still cant open dam store till these issues are all sorted :mad:
pigment ink fired into the other brother 5910.....black and reds coming out faded as hell on normal print paper....even with bumping up the settings to best/enhanced ect...faded as hell....
not the look as was hoping for here tbh...more colour depth with the ordinary inks that came with the printer :rolleyes:
dont know if pauls profile would help get the colour depth back
still trying all sorts.....will be back.
ps..sorry i aint been on here lately, been balls to the wall with this dam store.....never thought cleaning up images in photoshop would take up soooooo much dam time :mad:....and still got 2 sections of products to do....
stress aint the dam word for it guys:rolleyes:
WorthDoingRight
Post by WorthDoingRight »
@bigj2552 Good luck with it all mate and hope it finally all comes together good for you
bigj2552
Post by bigj2552 »
WorthDoingRight;52511 wrote:@bigj2552 Good luck with it all mate and hope it finally all comes together good for you
Hi worth, how ya doing bud ?.....better luck with your store and other things than me at the moment....least yours is OPEN !!.
just tryed same print job on my sub brother printer....using same pauls profile...colours came out WOW...as i expected.
so......
me thinking either - pigment inks are total **** and a waste of cash or.......
i need to get paul to profile this other brother printer like ASAP
JSR
Post by JSR »
bigj2552;52510 wrote:not having a good time here at all bud....
Try some coated paper, including glossy paper. You'll need a custom profile, too.
It's going to looked washed out on plain paper, particularly if you haven't got a profile made. Pigment inks work slightly differently to dye inks.
I've had some pretty good results on coated paper with my custom profile. Not 100% just yet, but my profiler device isn't as good as Paul's.
bigj2552
Post by bigj2552 »
JSR;52513 wrote:Try some coated paper, including glossy paper. You'll need a custom profile, too.
dont have any othr paper here bar plain copier paper....well, my sub papers are there but i dont want to waste one if its needing profiled..messaged paul....:wink:
WorthDoingRight
Well I need to get a profile sorted but in process of deciding whether to move sublimation to an Epson S22 and flush my brother for pigment inks for A3 t-shirt transfers. I can use the laser printer for A4 t-shirts etc. Decisions Decisions! Currently however everyone I see wants flex names and logos on shirts and not images - just got to convince them to place an order.
who wants to wear A3 paper on the chest??? :rolleyes:
bigj2552
Post by bigj2552 »
just printed out same design onto light transfer paper....cheaper stuff another company ( aint using the good yoyo stuff )
still printing out faded with the pigment inks....
pauls fireing me out the stuff to get it profiled :wink:
why is it so far out colour wise ?
the other brother printer with the sub inks printed straight out the box with the sub inks,with a bit of tweaking / without any profile.....these dam pigment inks, i got settings up MAX, and its still crap :rolleyes:
JSR
Post by JSR »
bigj2552;52525 wrote:not the look as was hoping for here tbh...more colour depth with the ordinary inks that came with the printer
Because pigment inks aren't dye inks. Pigment inks consist of small solid particles of colour, dye is partially transparent dye. Dye soaks into the paper, pigment ink sits on top of the paper. Dye is water soluble, pigment is waterproof. Dye ink typically has a larger colour gamut than pigment ink.
They are so different you may as well be comparing wool dye with laser toner. That we get anything even remotely close with a profile designed for dye inks is remarkable in itself.
If you were putting these pigment inks into a printer that uses OEM pigment inks then you'd probably get a comparable result with putting third-party dye inks into an OEM dye-ink printer.
I've just done some print tests with my "test doggie photo" on my MFC-5890CN with third-party dye inks (using a custom profile by Paul) and my DCP-195C with third-party pigment inks (using my own custom profile) using bog-standard Kodak glossy photo paper and Epson Photo Paper.
The two prints are virtually identical. The only difference is that the dye-ink on the Kodak paper smudged when removing it from the printer (it needs to dry on this paper, but not on the Epson paper), the pigment ink didn't.
One thing to remember is your settings you used when making your custom profile. I printed first with the printer set to "Other Photo Paper", and then to "Inkjet Paper" (which is what I used when making the profiles). The difference is huge in both cases.
On the DCP-195C, the "Other Photo Paper" gives a green cast. It's kind of acceptable, but not if you're discerning. Using the "Inkjet Paper" setting (used to create the profile), the print is virtually perfect.
On the MFC-5890CN, the "Other Photo Paper" setting leans towards the reds. Again, it's acceptable, but not really. Using the "Inkjet Paper" setting (used to create the profile), the print is as near to perfect as makes no odds.
Using the correct settings with the custom profiles - despite using different printers, and despite the profiles being made on different profiling devices, and despite using different inksets - both prints are almost identical. If anything the pigment print is slightly more colourful/saturated, but it's barely noticeable. The difference between papers (Kodak vs Epson) isn't huge considering that I made the profiles using Epson Photo Quality Inkjet Paper, not glossy paper, (the Epson Photo Paper produces ever so slightly more pleasing results, but the Kodak paper produces darker blacks) so this isn't as big a factor in getting the colours as ensuring your print settings are as they were when making the profile.
Based on these tests, I think you'll be fine as soon as you get your profile made up.
bigj2552
Post by bigj2552 »
thanks for the info bud....good read as always .....and i hope it works..
