Cheap subli ink
JSR
Re: Cheap subli ink
Post by JSR »
AdamB;22765 wrote:Just for clarity,
are we talking A3+ as a large format printer, or bigger than this (i.e large format being A2, A1 ->)
I believe large format refers to 17" and larger - although there was some discussion once that 17" might not be large enough, because you can get 17" printers that can fit on a desktop these days.
Andrew
Re: Cheap subli ink
Post by Andrew »
Wide format is 40" or there abouts - the 9000 epson series and up I thought. The 17" 4000 series is not covered and neither supposedly is the 7000 range which is crazy if you saw the size of it. We have had a couple of 4000 series as well as the 9000. Not sure who on earth thought it was justifiable to call the 7000 a desktop and not wideformat.
JSR
Re: Cheap subli ink
Post by JSR »
Blimey, it's worse than I thought...! :eek:
AdamB
Re: Cheap subli ink
Post by AdamB »
Thanks guys :-(
Ian M
Re: Cheap subli ink
Post by Ian M »
I quote from the said email
'The approved (licensed) use is for 42" and above printers only (Large Format)'
Ideal for sublimating tents, hot air baloons, marquees etc.....................Grrrrrrrrrrrrrr!
Re: Cheap subli ink
AdamB;22645 wrote:Check this out ............... a DSF Members experiment :-)
aRE WE GOING TO CRACK ON WITH IT OR NOT?? :) WOULD BE INTERESTING TO SEE TH RESULTS. ALSO i LOVE TO TRY some prints from ricoch printer...
AdamB
Re: Cheap subli ink
Post by AdamB »
Paul;23370 wrote:aRE WE GOING TO CRACK ON WITH IT OR NOT?? :) WOULD BE INTERESTING TO SEE TH RESULTS. ALSO i LOVE TO TRY some prints from ricoch printer...
As far as I knew I thought kris_hm was sending you the image for you to test ??????????
Re: Cheap subli ink
yes. true. I but decided to qute you as i liked this post and thought it would be good DSF Members experiment :)
AdamB
Re: Cheap subli ink
Post by AdamB »
Paul;23375 wrote:yes. true. I but decided to qute you as i liked this post and thought it would be good DSF Members experiment :)
That 'was' the experiment Paul ................. print off design with inks, send onto someone else, they press them onto mugs and then posts up results to compare ;-)
Re: Cheap subli ink
yee. would be great! any one up for it???
Would be good to have ricoch users and those who dont use profiles but geting good results.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 3 guests
