Cheap subli ink
JSR
Re: Cheap subli ink
Post by JSR »
AdamB;22765 wrote:Just for clarity,
are we talking A3+ as a large format printer, or bigger than this (i.e large format being A2, A1 ->)
I believe large format refers to 17" and larger - although there was some discussion once that 17" might not be large enough, because you can get 17" printers that can fit on a desktop these days.
Andrew
Re: Cheap subli ink
Post by Andrew »
Wide format is 40" or there abouts - the 9000 epson series and up I thought. The 17" 4000 series is not covered and neither supposedly is the 7000 range which is crazy if you saw the size of it. We have had a couple of 4000 series as well as the 9000. Not sure who on earth thought it was justifiable to call the 7000 a desktop and not wideformat.
JSR
Re: Cheap subli ink
Post by JSR »
Blimey, it's worse than I thought...! :eek:
AdamB
Re: Cheap subli ink
Post by AdamB »
Thanks guys :-(
Ian M
Re: Cheap subli ink
Post by Ian M »
I quote from the said email
'The approved (licensed) use is for 42" and above printers only (Large Format)'
Ideal for sublimating tents, hot air baloons, marquees etc.....................Grrrrrrrrrrrrrr!
Re: Cheap subli ink
AdamB;22645 wrote:Check this out ............... a DSF Members experiment :-)
aRE WE GOING TO CRACK ON WITH IT OR NOT?? :) WOULD BE INTERESTING TO SEE TH RESULTS. ALSO i LOVE TO TRY some prints from ricoch printer...
AdamB
Re: Cheap subli ink
Post by AdamB »
Paul;23370 wrote:aRE WE GOING TO CRACK ON WITH IT OR NOT?? :) WOULD BE INTERESTING TO SEE TH RESULTS. ALSO i LOVE TO TRY some prints from ricoch printer...
As far as I knew I thought kris_hm was sending you the image for you to test ??????????
Re: Cheap subli ink
yes. true. I but decided to qute you as i liked this post and thought it would be good DSF Members experiment :)
AdamB
Re: Cheap subli ink
Post by AdamB »
Paul;23375 wrote:yes. true. I but decided to qute you as i liked this post and thought it would be good DSF Members experiment :)
That 'was' the experiment Paul ................. print off design with inks, send onto someone else, they press them onto mugs and then posts up results to compare ;-)
Re: Cheap subli ink
yee. would be great! any one up for it???
Would be good to have ricoch users and those who dont use profiles but geting good results.
