Ovens to Mug Presses...anyone done it?
gazfocus
Re: Ovens to Mug Presses...anyone done it?
Post by gazfocus »
JMugs;149536 wrote:I ran a small oven that held six mugs for a while (9 would have been possible), so not quite the same scale. My studio was always cold in the winter so I used a second oven set at 40 degrees to preheat mugs, my random failures became very few. Bonus was I stopped making adjustments from winter to summer.
This would illiminate the cold spots issue.
Janners
Can I ask how long you pre heated the mugs for?
rgsearley
Post by rgsearley »
gazfocus;149537 wrote:Can I ask how long you pre heated the mugs for?
even in a press I have to preheat especially on full prints
you need to preheat long enought that the thick base on the mug is heated through... at these temps it's too cold to sub so can't over do it
in my press I preheat at 100 degrees for about 3 minutes.. long enough that when I touch the base in the centre it's no longer cold
Sent from my SM-G998B using Tapatalk
gazfocus
Post by gazfocus »
rgsearley;149539 wrote:even in a press I have to preheat especially on full prints
I have to be honest, in the years that I’ve printed mugs (and we do hundreds a day), we’ve never pre heated a mug, ever.
That being said, I wouldn’t discount it’s benefits and I will definitely give it a try. We have 5 ovens at present so plenty to play with.
We have also just had a quantity of mug presses delivered to help over Christmas and I’ve bought a hot plate to pre heat the bottoms of the mugs.
rgsearley
Post by rgsearley »
gazfocus;149540 wrote:I have to be honest, in the years that I’ve printed mugs (and we do hundreds a day), we’ve never pre heated a mug, ever.
I only ever do full top to bottom prints... unless it's mid summer the mug bases are too cold and don't sub..
Sent from my SM-T970 using Tapatalk
gazfocus
Post by gazfocus »
rgsearley;149541 wrote:I only ever do full top to bottom prints... unless it's mid summer the mug bases are too cold and don't sub..
Thanks, will certainly give it a go. Roughly how long do you pre heat for in the oven?
Thanks again
rgsearley
Post by rgsearley »
gazfocus;149542 wrote:Thanks, will certainly give it a go. Roughly how long do you pre heat for in the oven?
Thanks again
3 - 4 minutes longer if really cold..
JMugs
Has thanked: 10 times
Been thanked: 10 times
Post by JMugs »
They were in for as long as the others were cooking, so the six mugs came out on a tray and were wrapped, then put in the main oven to cook. Leaving them on the tray while I wrapped them kept the warmth in them. So pop the six in the main oven, put a fresh six on the tray, pop in the other oven to warm.
Janners
gazfocus
Post by gazfocus »
JMugs;149545 wrote:They were in for as long as the others were cooking, so the six mugs came out on a tray and were wrapped, then put in the main oven to cook. Leaving them on the tray while I wrapped them kept the warmth in them. So pop the six in the main oven, put a fresh six on the tray, pop in the other oven to warm.
Janners
Thanks for that. So you let them pre heat before wrapping them? I’ll give that a go. Thank you :)
JMugs
Post by JMugs »
gazfocus;149546 wrote:Thanks for that. So you let them pre heat before wrapping them? I’ll give that a go. Thank you :)
Yes, preheat before wrapping.
Janners
JMugs
Post by JMugs »
I have just dug out my small oven after a lot of searching I found a wrap. 1 mug 15 minutes. The dial shows 175, the thermometer inside shows 205, I doubt either is accurate. Rhino coated mug prints a treat. Just ordered some new wraps.
Reason...?
If there is a problem with my presses in the run up to Christmas, then it's back to the oven!
This thread prompted me, so thanks folks.
Janners
