Page 4 of 11
Re: MDP mug press. Read here owner review and pics.
Posted: 01 Jun 2021, 21:21
by Mrteajunkie
Take a side pic of the mug in the press with it closed.
The problem is you have a press which is most likely a clone.
When the handle gets to the halfway point you should start to feel a light pressure on the mug.
The spring loaded bolts should never be moved.
Posted: 01 Jun 2021, 21:28
by Tony4415
bear in mind its a FREESUB which I stated at the beginning, [ATTACH=CONFIG]6703[/ATTACH][ATTACH=CONFIG]6704[/ATTACH]yours probably doesn't say FREESUB.
heres x2 picture of side view and front.
Posted: 01 Jun 2021, 21:31
by Mrteajunkie
Tony4415;148402 wrote:bear in mind its a FREESUB which I stated at the beginning, [ATTACH=CONFIG]6703[/ATTACH][ATTACH=CONFIG]6704[/ATTACH]yours probably doesn't say FREESUB.
That looks tight enough to me.
Open the press tighten the thumbscrew and close it again.
dont get me wrong it needs to be a snug fit but not really tight fit.
as long as the mug doesn’t move in the press when closed.
Posted: 01 Jun 2021, 21:36
by Tony4415
Ok I thought it had to be firm pressure I read this on this forum, like medium to hard pressure to get good image contact.
I will try as is at the moment with both screws tighten (light-medium pressure) tomorrow.
but thanks with all your help today, much appreciated. top man!
Posted: 01 Jun 2021, 21:38
by Mrteajunkie
Tony4415;148404 wrote:Ok I thought it had to be firm pressure I read this on this forum, like medium to hard pressure to get good image contact.
If it comes to it take a video of the handle going down so I can see what pressure your applying and how your interpretation of firm compares to mine ;)
Posted: 01 Jun 2021, 22:01
by Tony4415
How do you upload a video file?
Do you have email address please?
Posted: 01 Jun 2021, 22:04
by Tony4415
well I don't know how to upload a video file.
If I explain... I can close the press with 110z mug inside with my index finger, light pressure.
Posted: 01 Jun 2021, 22:09
by Mrteajunkie
Tony4415;148407 wrote:well I don't know how to upload a video file.
pmd you email.
Posted: 01 Jun 2021, 22:23
by Mrteajunkie
Looks good to me fella.
have a trial run and let us see the result. ;)
Posted: 01 Jun 2021, 22:24
by Tony4415
will do thanks again!
