Great info, love the idea of slide over sleeves I assume you will just tape the joint holding the wrap around the box?
I do have a SG400 with the standard supplied inks and truepix paper, will have too see if we have a supplier this side of the pond.
If not coming over to Uk in a few weeks time and see what I can find.
On another note anywhere near Widderington I spent a bit of time there working on open cast for Ruston Bucyrus a few moons ago now.
LB
FRP sheets...
Re: FRP sheets...
I have been looking for Mylar as already mentioned by Webtrekker not much joy here in Ireland, small sheets sold by art shops mainly.
Found idealstencils.co.uk they sell by the roll.
I am heading over to Derby in a few weeks time is there anything else I should take advantage off whilst there ( UK that is ) in relation to the items discussed in this post.
I have found that CIE are in Derby somewhere, not sure if you can walk in off the street.
LB
LB
Re: FRP sheets...
Hi LB. I get my stencil sheets from A. S. Handover - https://www.handover.co.uk/mylar-stenci ... 0-x-600-mm but they are London-based I believe.
There are loads of suppliers of cast acrylic sheet, so you may well find some in the Derby area.
Re: FRP sheets...
Just been playing around with some mylar mug box sleeves for the cardboard crush-proof boxes ...
They certainly cheer up these plain boxes. Printed on one A4 sheet of sub paper, the design covers the three visible faces of the box. The Mylar was cut to 450mm x 105mm and joined underneath with double-sided sticky tape.
The only modification I might make in future is to make the sleeves the full width of the box to make them easier to slide on and off.
Re: FRP sheets...
They look mighty, It's the little things that count.
Chances are one of their kids might reuse the wrap for a project, maybe add your brand endless possibilities.
LB
LB
Re: FRP sheets...
Another experiment!
I sub printed a couple of 100mm square coasters for the grandkids...
[ATTACH=CONFIG]5669[/ATTACH]
[ATTACH=CONFIG]5668[/ATTACH]
Again, this is just plain old cast acrylic, no special coatings.
- vB_ID:5668
- 20190401_173110.jpg (94.88 KiB) Viewed 257 times
- vB_ID:5669
- 20190401_173047.jpg (86.5 KiB) Viewed 257 times
