Issues with Ricoh SG3100 DN
Re: Issues with Ricoh SG3100 DN
In the printer set up, the document profile shows as SRGB. Is this because the file was created in this profile? I try to change to ProPhoto RGB in the Printer Profile underneath but doesn't update the Document profile.
mags1892
settings for powerdriver are Srgb, for direct its ADOBE RGB but switch off profile in printer driver and use photoshop or illustrator to do colour, prophoto is wayyyyy too big a profile its basically what camera raw is.
Ok mate.
Ive got my head around it now (still not printing the way i want it to though!)
How do i switch off the profile in the printer driver? Cant see it anywhere?! Going to give Adobe 1998 another shot:)
I can see you are all queing up in anticipation waiting to respond to my previous 10 posts in this thread. Well you can hold off for now as the mayor of Newcastle Mags has saved the day by remote accessing my PC. I Powerdriver is garbage. Back on Adobe 1998. Cheers everyone, I knew that something could be done:)
mags1892
technick;110242 wrote:I can see you are all queing up in anticipation waiting to respond to my previous 10 posts in this thread. Well you can hold off for now as the mayor of Newcastle Mags has saved the day by remote accessing my PC. I Powerdriver is garbage. Back on Adobe 1998. Cheers everyone, I knew that something could be done:)
lol Mayor I think Newcastle would be DOOMED if I was that, ill have the Newcastle United Managers job though Noone can F*&^ that up any more than it is
sorry, missed all this yesterday - if Mags didn't point this bit out - in proofing, device to simulate is your printer - you need to select your printer ICC here, and this should give you a good representation of what is going to print out, for you to then make the necessary tweaks.
mags1892
I didpisquee;110262 wrote:sorry, missed all this yesterday - if Mags didn't point this bit out - in proofing, device to simulate is your printer - you need to select your printer ICC here, and this should give you a good representation of what is going to print out, for you to then make the necessary tweaks.
