Hi Arthur
Not a daft question at all. I had that 'lightbulb' moment but unfortunately I am printing on the correct side of the paper.
Did try another image and not quite right either....going down the head clean, repeat, etc that Scotty has suggested. Good tip about a colour patch text....am going to do that once I have this issue resolved.
Colour Change
Re: Colour Change
I had the same problem with a mug image, i printed the image, showed the customer,brill,did not notice the first print out was with the profile and the second wasn't, difference was slight , so check your profile settings
Directdesignsupplied.co.uk
Re: Colour Change
Must have done about a dozen cleans and still not back to normal
Angloman...what is the profile setting you talk of? can this really get even more complicated
Re: Colour Change
Failing all this, can you just enhance the image itself slightly. Play with the colour values. Sometimes you have to cheat the process
Re: Colour Change
I'm having the exact problem. 170 for 120 secs. The black seems to be brown and really faded around the edges. Sooo annoying. Will have to have a play about with it later but I've now got four duff mugs
