Printing on the Bottom of Sub Mugs.
arthur.daley
Re: Printing on the Bottom of Sub Mugs.
Post by arthur.daley »
NikGrey;79662 wrote:Just about to print another sheet of these Mug Base Stamps - before I mess with the colours can someone remind me which paper setting lays down the most ink ? I think I did some testing and found Plain paper seemed to lay the most ink but am not certain.
Hi Nik
Not sure you need to lay down more ink?? It looks as though you have enough coverage and therefore if you go say 30% darker colourwise you ougght to get a better print? - well maybe ;o)
If you over ink the paper is there a chance of the paper wrinkling?
Your puck - which way up are you using it?? Piston the the mug or silicon to the mug?
Arthur
NikGrey
Post by NikGrey »
Silicon on the Mug, the piston is against the heat pad and is supposed to transfer the heat.
It wouldn't work the other way around as it is, it would take me too long to mirror the contour of the mug base onto the Piston - I'm not sure I could even get it accurate enough.. I always wanted a Lathe - maybe now is the excuse I need :)
I have made a Jig now, so less chance of error when placing the mug.
DANNYD
Post by DANNYD »
Do you think this idea wold work using the mini 3d?
vB_ID:3331
vB_ID:3331
yes, as long as the pressure is good enough and the mugs have been coated on the bottom (not all of them are)
mrs maggot
Post by mrs maggot »
at one of the shows i got some transfers which are applied under heat/pressure still got to try them, obviously then they are printed up with whatever you want on the bottom - still not tried them yet. but i know where they are, so if you want to try some nik let me know and i will pop some in the post
guarddog14
Post by guarddog14 »
does chongsta still do the stickers? im kinda desprate for some
Yes he does
James990
Post by James990 »
and they are great stickers as well! I now use them!!
James
