Ricoh SG3110DN Black and White image problem
WorthDoingRight
Re: Ricoh SG3110DN Black and White image problem
Post by WorthDoingRight »
Well lets hope the result is good enough for your needs and that maybe Sawgrass can figure out the issue if it exists withing their Powerdriver.
WorthDoingRight
Justin;57614 wrote:If in doubt don't answer!!! :tongue:
I never doubt my answers, they are just sometimes not to everyones liking :rolleyes:
just4yougifts
Post by just4yougifts »
Sorted. It needed to be selected as a 'greyscale' image in the powerdriver setting. I had only tried it by setting greyscale in the paint shop pro and it hadnt effected it. Also, using the old Epson 1400 before the images came out fine without setting greyscale so didnt bother with the new Ricoh printer.
Thanks for any help.
carter2
Post by carter2 »
The same problem happened with me..I'll suggest you to print 1-2 sheets again so that it comes back in its normal form...Cleaning won't help much:(
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 1 guest
