er.....:redface:Paul;49521 wrote:50cm wide rolls
Cutter .. Cameo ?
Re: Cutter .. Cameo ?
Dunno if anyone else as noticed this but the new update i received this week for the Cameo as messed up the Viny cutting settings .. On standard Heatpress vinyl it tells yout to set the blade to 2 and the speed sets auto to 8 and thickness to 7 (lmao) doesnt even scratch it ..
Luckly i wrote down some custom settings for future use and for standard vinyl i use 7 speed : thickness 17 : blade setting 2 .. Works perfect (for me)
500mm wide is what im using i believe , brought a few 1 meter sheets from MDP to try works great .. Good advice given glad i took it
thank you
thank you
Thickness 17 ?. What you cutting concrete ?Kahboose;49526 wrote:Dunno if anyone else as noticed this but the new update i received this week for the Cameo as messed up the Viny cutting settings .. On standard Heatpress vinyl it tells yout to set the blade to 2 and the speed sets auto to 8 and thickness to 7 (lmao) doesnt even scratch it ..
90% of my use is MDP hot flex, and it's speed 8 thickness 7.
IM using MDP hotflex , the standard setting doesnt touch it .. mmmm /me ponders ..
Though the wife just said we were using the holographic vinyl so maybe thats why .. dunno otherwise ..
this guy is having a similer issue ,, http://www.digitalprimes.com/index.php/ ... vinyl-tips
Could i ask what blade stting your using ? (1?)
I have the actual blade set on 2 and the software blade setting at 2.Kahboose;49553 wrote:Though the wife just said we were using the holographic vinyl so maybe thats why .. dunno otherwise ..
When I use the Cool Flex sparkly stuff from MDP I change the settings to blade 3, speed 8 and thickness 12, but I also have double cut ticked as well
do you double cut all the time ? or just on the cool flex ?
sorry for all the questions just trying to narrow down if its something im doing incorrect
thanks for the help
thanks for the help
No double cut on the standard flex, just the thicker sparkly stuffKahboose;49556 wrote:do you double cut all the time ? or just on the cool flex ?
thanks for the help
ok , thanks for the input going to try that i think .. maybe the blade set to 1 was the problem
