Cutter .. Cameo ?
bigj2552
Re: Cutter .. Cameo ?
Post by bigj2552 »
Paul;49521 wrote:50cm wide rolls :-)
er.....:redface:
Kahboose
Post by Kahboose »
Dunno if anyone else as noticed this but the new update i received this week for the Cameo as messed up the Viny cutting settings .. On standard Heatpress vinyl it tells yout to set the blade to 2 and the speed sets auto to 8 and thickness to 7 (lmao) doesnt even scratch it ..
Luckly i wrote down some custom settings for future use and for standard vinyl i use 7 speed : thickness 17 : blade setting 2 .. Works perfect (for me)
Kahboose
Post by Kahboose »
500mm wide is what im using i believe , brought a few 1 meter sheets from MDP to try works great .. Good advice given glad i took it :)
thank you
accdave
Post by accdave »
Kahboose;49526 wrote:Dunno if anyone else as noticed this but the new update i received this week for the Cameo as messed up the Viny cutting settings .. On standard Heatpress vinyl it tells yout to set the blade to 2 and the speed sets auto to 8 and thickness to 7 (lmao) doesnt even scratch it ..
Thickness 17 ?. What you cutting concrete ? :)
90% of my use is MDP hot flex, and it's speed 8 thickness 7.
Kahboose
Post by Kahboose »
IM using MDP hotflex , the standard setting doesnt touch it .. mmmm /me ponders ..
Kahboose
Post by Kahboose »
Though the wife just said we were using the holographic vinyl so maybe thats why .. dunno otherwise ..
this guy is having a similer issue ,, http://www.digitalprimes.com/index.php/ ... vinyl-tips
Could i ask what blade stting your using ? (1?)
accdave
Post by accdave »
Kahboose;49553 wrote:Though the wife just said we were using the holographic vinyl so maybe thats why .. dunno otherwise ..
I have the actual blade set on 2 and the software blade setting at 2.
When I use the Cool Flex sparkly stuff from MDP I change the settings to blade 3, speed 8 and thickness 12, but I also have double cut ticked as well
Kahboose
Post by Kahboose »
do you double cut all the time ? or just on the cool flex ?
sorry for all the questions just trying to narrow down if its something im doing incorrect :)
thanks for the help
accdave
Post by accdave »
Kahboose;49556 wrote:do you double cut all the time ? or just on the cool flex ?
thanks for the help
No double cut on the standard flex, just the thicker sparkly stuff
Kahboose
Post by Kahboose »
ok , thanks for the input going to try that i think .. maybe the blade set to 1 was the problem ;)
