Ricoh 3110 - Orange is Printing Red
Ucase Ltd
Re: Ricoh 3110 - Orange is Printing Red
Post by Ucase Ltd »
Spike1865;100657 wrote:Hi Paul
Do you have a ICC for this machine dude? I'd like one to use with Gimp. Many said you are the man for ICC'S but I never caught you around!
pisquee wrote: If you're using Photoshop, then you should the ICC and let Photoshop do its job, and not hold it back with PowerDriver. If you have colour management set up correctly in Photoshop it is a much more powerful tool, especially if you put it into proof view with the out of gammut view on (even more so if your monitor is calibrated) as it will give you an onscreen approximation of how the colours will print out as well as show colours it can't print. Doing this with a custom ICC will give you the best colour printing accuracy available for your printer/ink/transfer paper combination.
This sounds like exactly what I need, I've only ever just followed instructions from Sawgrass. Never setup an ICC but I'll do some research and give it a try.
Cheers,
John.
Cheers,
John.
Sawgrass has icc and instruction as well. very easy to follow ;)
for what machine?
Spike1865
Post by Spike1865 »
Paul;100679 wrote:Sawgrass has icc and instruction as well. very easy to follow ;)
for what machine?
For the 3110 Paul. But I think you said it was on Sawgrass. I thought the PowerDrive was the profiler...
Ucase Ltd
Post by Ucase Ltd »
Thanks! - I'll give it a try as soon as I get time.
Spike1865;100682 wrote:For the 3110 Paul. But I think you said it was on Sawgrass. I thought the PowerDrive was the profiler...
yes. you can get just ICC file from sawgrass if you dont want to use powerdriver. or you on mac.
