Cup and Saucer?
sarahann
Re: Cup and Saucer?
Post by sarahann »
Hi Adam,
I've just seen this thread and we have a coffee set that may be of interest to you- it comes with the cup, saucer and a spoon. Just an alternative that you might want to see.
Here is a link to the product:
[url="http://www.etcsupplies.co.uk/product_in ... cts_id=319]http://www.etcsupplies.co.uk/product_in ... cts_id=319[/url]
Hope this helps.
AdamB
Re: Cup and Saucer?
Post by AdamB »
sarahann wrote:Hi Adam,
Hope this helps.
Yeah - I was looking at the set yesterday.
It says that you need the 'mini press' but would a standard press with an additional wrap/blanket on the cup suffice?
Many thanks for the reply.
And, got your PM - I will reply back shortly.
AB
sarahann
Re: Cup and Saucer?
Post by sarahann »
You can use the mini mug press or the larger mug press as long as it has a 5 - 7.5cm wrap.
JSR
Re: Cup and Saucer?
Post by JSR »
Hope this helps.
That looks interesting. I've bookmarked it.
I presume it can be pressed in an oven with a wrap, too? I sometimes press China mugs in this way which, although taller, are just 6.8cm diameter.
sarahann
Re: Cup and Saucer?
Post by sarahann »
Yes it can be pressed in the oven with a wrap. The crucial part would be to make sure the wrap it tightly placed on the mug and the heat generated in the oven should be high enough.
Any problems, feel free to get in touch :)
