Continuous pressing - questions!
Re: Continuous pressing - questions!
mfacer;88236 wrote:So is 200C set as the 'idle' temp for the process above?
none have our presses have more than one temp setting - I'd be sending back a press if we couldn't use it continuously, as it would be useless for us needing to print lots of mugs.
mfacer
Post by mfacer »
If poss, could you share which press it is? I'd love one which I could just switch on and leave. It honestly drives me MAD having to use the timer. The beeping is unbelievably loud.
It's these - http://www.ebay.co.uk/itm/2-3-4-5-IN-1- ... 3f2172b622
We use the timers on them to count down each mug, but that is the only time it beeps - when the timer runs out.
Dave271069
Post by Dave271069 »
4. just before 0, switch off press and take mug out, plunging in to water.
i found the mugs i was putting into water were getting cracked quite often, beware of this as it can happen and hairline cracks can appear,
mfacer
Post by mfacer »
Dave271069;88244 wrote:i found the mugs i was putting into water were getting cracked quite often, beware of this as it can happen and hairline cracks can appear,
I have had a couple do that actually. I try to keep the water more on the warm side than ice cold. I heard this should be done to stop the transfer as often it can bleed if the mug is still warm? I guess it depends on the mug or the time you've pressed though?
mfacer;88246 wrote:I have had a couple do that actually. I try to keep the water more on the warm side than ice cold. I heard this should be done to stop the transfer as often it can bleed if the mug is still warm? I guess it depends on the mug or the time you've pressed though?
I've only seen this happen when we had to quickly get in a load of cheap 10oz mug. Our usual custom made mugs don't seem to do this.
