Ah right what sort of time length do you think I would need to give them?
really appreciate all the comments and help people
EDIT: will the paper be ok to use to print on then still?
Printing help needed
Re: Printing help needed
I think Ushi might be right...Although I doubt that film case would be considered "cheap blank phone case"..
If it's a film case, I think you can only print it using film at a much lower temperature than 190C.
ushi;84680 wrote:look like u got the film case, their printing temp is 140c not 190c.
This is the reply I got from supplier... So in the following time for the sublimation u can :silk printing ,digital printing ,watertransfer printing ,rubber oil /uv oil ...This case can do that .
