Page 2 of 5
Re: Mug Printing problem - probably not the first!!!!
Posted: 19 Jan 2014, 14:36
by danno
Well, I actually put half the mug in the pressfor 45 secs, then placed the image, then cooked it....apologies I should've been clearer on that. That was to get the base hot, do you think that's a good idea or not??
Posted: 19 Jan 2014, 14:56
by danno
Ok, here's the latest one done (on the right)
I covered more of the mug this time to really push it! The crinkles have gone, so maybe that was my error in placing the image, I also put half the mug in for 45 secs before placing the image.
For one the colours are a lot stronger than the first one, but some of the clouds have a little bit of a red tinge to them, so could that be too much heat??
But the bottom is still faded, admittedly it's a taller image. So not quite sure on that one whether I've still got to increase the pressure, or what.....any ideas?
this one it's difficult to see, but the clouds have a little bit of a red tinge to them (right hand mug)......so I'm thinking maybe go back to 180c for 180 secs?? Any thoughts guys??
Cheers
Dan
Posted: 19 Jan 2014, 15:03
by Paul
I would definitely do it for longer once image is on the mug. Also don't put to much pressure on it. Just enough to close it and keep mug tight. If you put to much pressure on it image will lose its sharpness.
also you can try to flip mug over in last 60sec.
Posted: 19 Jan 2014, 15:10
by danno
Hi Paul, do you mean cook it for longer.....there seems to be a rogue "o" in your post lol
Also one other thing I do that I read somewhere (which may be wrong), after I place my image, I wrap the mug in a piece of A4 paper, apparently it protects the blanket from stray ink.....I'mthinking this may also cause me a problem???
Paul;82327 wrote:I would definitely o it for longer once image is on the mug. Also don't put to much pressure on it. Just enough to close it and keep mug tight. If you put to much pressure on it image will lose its sharpness.
Posted: 19 Jan 2014, 17:00
by danno
well a further little update and 2 more mugs going to the charity shop! I got my Infra red thermometer out and cooked a mug at my current settings of 190c. For one it seems that the temperature given on the display is out by about 40c, The blanket didn't go above 160c (In the middle), and the mug got to just over 150c.......the base of the mug showed about 80c (mug warmed on the radiator for about 5 mins) so for one it would seem heating the base of the mug is essential using this press, and also upping the cooking temperature.
Been thinking a lot about this setup, and I'm thinking that if I raise the cooking temp by quite a bit (judging by my temp readings) I will not need so long to cook a mug otherwise I may get blowout problems OR do I keep the temp at 190c and cook for longer??? Any thoughts guys?
I am now down to my last 10 mugs!!!! So I'll be needing to get some more......any recommendations for where is the best place to buy for the straightest mug??
Posted: 19 Jan 2014, 17:14
by RogerC
danno;82336 wrote:well a further little update and 2 more mugs going to the charity shop! I got my Infra red thermometer out and cooked a mug at my current settings of 190c. For one it seems that the temperature given on the display is out by about 40c, The blanket didn't go above 160c (In the middle), and the mug got to just over 150c.......the base of the mug showed about 80c (mug warmed on the radiator for about 5 mins) so for one it would seem heating the base of the mug is essential using this press, and also upping the cooking temperature.
No doubt others will have recommendations but for me BMS. I buy from them and have 'never' had any problems.
http://www.printerowners.co.uk/
Posted: 19 Jan 2014, 17:26
by danno
Ok Roger,thanks for the info.....I'm just starting a new thread on mug ID!!! I have a mug I got ages ago, which is a really nice quality product, would love to know where it comes from!
Posted: 19 Jan 2014, 17:35
by Paul
o it for longer and compare.
Posted: 19 Jan 2014, 17:47
by danno
Paul;82340 wrote:o it for longer and compare.
I think you've lost your D paul!!! I did do it for longer, and it was just as rubbish!!! So I'm leaning towards my temperature not matching what it says on the display.
Ok as an aside thing here....not going to start a new thread as I don't want to clog up the forum with nonsense! so I'll put it here.....Below is an image of one of my recent disasters and a Mug I was bought a couple of years ago, now I know this is a daft question, but can anyone identify the mug on the left, it has a flatter handle, slightly shorter, but is a really nice very shiny mug, it also has a very small "tag" for want of a better word on the base (like a very faint circle with something in it - a letter maybe?), which you can't see in the photo! lol.....any ideas anyone?
Posted: 19 Jan 2014, 17:54
by gorgall2
Looks like BMS.
