Cutter Software = what do you use
Any OS, software in here.
Re: Cutter Software = what do you use
mrs maggot;73278 wrote:paul looks to be around the same price as sign cut, i quess both will take some getting used to.
do know where you looked Laura but signCut cost $348
and flexi starter 10 with contour cut option £79.95 as is on offer now. http://www.signwizard.co.uk/flexisign-f ... g-software
Flexi is more simple to use then signblazer.
mrs maggot
Post by mrs maggot »
oh that is cheaper paul than where i looked, as they had it on for $240 so i thought i could have a lifetime use for just under $300 is the flexi a forever use, or time limited ??
mrs maggot
Paul, i know that version has a dongle, will i be able to use it on a computer and on a laptop providing i have it loaded onto both machines, and just move the dongle to whichever i am using ??
Yes. This best about this software. You can install it on as many pc you want and just have tiny usb stick with you. Sign cut i think you have subscription with them so you need interne access. In flexi case you can sale it on ebay if you decide to go for something new in future. And you can not with signcut. But correct me if iam wrong.
Also with flexi you can use one pc for designs and other for cut. This is over the network so you dont need more then one usb dongle ;)
What cutter you own laura?
logobear
Post by logobear »
Can I hijack this thread and ask if any of these packages will allow import of vector graphics from Illustrator or of EPS files?
Magicut software does not support these, and hence I have to jump through hoops to get the result.
Flexi is great for Ai and eps. As those thats i use.
mrs maggot
thanks paul i will order it today and give it a go, i have a secabo cutter and a couple of chinese cutters
No problem. I think you going to like it. I will record short video for other in cAse it can be any help for future ;)
arko
Post by arko »
Yes, as Paul says, Flexi can import AI, EPS and SVG files.... as can SignGo Pro.
