gradient fill problem
Re: gradient fill problem
here is illustration that will help you understand what gamut is:
[ATTACH=CONFIG]1803[/ATTACH]
vB_ID:1803
vB_ID:1803
In Paul's diagram, there would be another triangle type shape showing the colours achievable with your sublimation inks which would be smaller and inside the CMYK one.
hi!
I just had a look on your profile and i must say it has larger gamut then inkjet sublimation printer. so i dont think profile is the problem.
[ATTACH=CONFIG]1806[/ATTACH]
the white gamut is yours.
vB_ID:1806
vB_ID:1806
Screen Shot 2013-05-31 at 18.21.18.jpg (10.4 KiB) Viewed 263 times
The problem in this particular instance was because of how Corel treats gradient fills. If you ever need to go from a specific pantone to white it is always better to do it as a blend with a white box as a fill of 0% of said pantone. Gradient fills in Corel and handled by RGB process so will never do well with blues
viol8ion
Post by viol8ion »
What file type are you sending to RIP? I work with large format prints, CMYK, and use Adobe Illustrator for preflight, and gradients are always an issue. Some of my workarounds, and I don't know if they apply to your process, are to convert the AI file to TIFF rather than PDF to RIP. Sometimes I use Photoshop to convert the PDF to TIFF. I don't know if these steps will help or not, have no experience with Corel for years now.
Please check when you respond to threads, this thread is over 7 years old! Thanks, Justin
viol8ion
Post by viol8ion »
oops... sorry!
