Silhouette cameo carrier sheets
Re: Silhouette cameo carrier sheets
Vinyl isn't held in place whilst being cut/fed Paul.
alright. never seen this before. even on my little CRII
Johnny
Post by Johnny »
Faulty rollers?
A screw came lose on our cutter once, meant the handle didn't lower the rollers. Had to take the whole thing apart.
P4UL
Post by P4UL »
If you lose the 'tack' on the carrier sheet, which grips the vinyl to the sheet, you need to spray the carrier with a little mounting spray.
edit: the carrier sheet should last quite some time, without the need to be replaced.
Dave271069
Post by Dave271069 »
Evennig, i am tonight using my 12x24 mat for the first time, i have had a order for 30 hen do t-shirts (oh they are cheeky) and i needed to cut front and back full text across the t-shirt, anyway ive nearly finished the whole cut and i have not had a single issue with slipping or anything, very happy chappy!
viccar
Post by viccar »
The slipping refered to is when the vinyl is used without the carrier sheet.
Marius Titulescu
Post by Marius Titulescu »
viccar;71760 wrote:The slipping refered to is when the vinyl is used without the carrier sheet.
Is that recommended? It sounds like it's way less durable.
Please be aware this thread is over 8 years old!
