Silhouette cameo carrier sheets
Re: Silhouette cameo carrier sheets
alright. never seen this before. even on my little CRII
Faulty rollers?
A screw came lose on our cutter once, meant the handle didn't lower the rollers. Had to take the whole thing apart.
Day Out Photography
www.dayoutphotography.co.uk | facebook.com/DayOutPhotography | twitter.com/DayOutPhotos
m. 07817 118 717
m. 07817 118 717
If you lose the 'tack' on the carrier sheet, which grips the vinyl to the sheet, you need to spray the carrier with a little mounting spray.
edit: the carrier sheet should last quite some time, without the need to be replaced.
Shirt Printing Design and Culture teesandhoodies.com
Dave271069
Evennig, i am tonight using my 12x24 mat for the first time, i have had a order for 30 hen do t-shirts (oh they are cheeky) and i needed to cut front and back full text across the t-shirt, anyway ive nearly finished the whole cut and i have not had a single issue with slipping or anything, very happy chappy!
The slipping refered to is when the vinyl is used without the carrier sheet.
Marius Titulescu
Is that recommended? It sounds like it's way less durable.viccar;71760 wrote:The slipping refered to is when the vinyl is used without the carrier sheet.
