Teflon sheet? Pressing lines? A few noob questions...
Re: Teflon sheet? Pressing lines? A few noob questions...
mrs maggot;44737 wrote:I remember Paul showing a video where he used no sheet at all, but for most its common practice to use a sheet
i remember that :) it caused some talk on forum.
I normally use teflon sheet but in that case i didn't as i new this flex very well and i know nothing would happen. and never did :cool:
AdamB
Post by AdamB »
mrs maggot;44737 wrote:depending on which flex you are using for some now you must not press press, so the assumption that you pre-press all garments is not right..........
? Which flex Laura ?
Surely pre-pressing a garment or substrate is nothing to do with the flex or substrate you're using but merely a task to remove any moisture that is in the item.
I'm curious now ?
mrs maggot
Post by mrs maggot »
Adam 123 flex from magic touch is quite clear "do not pre press" its a new flex from them, that presses in 3 seconds, so any pre-pressing is out. just thought it was worth mentioning as i have to remember not to pre press when using it.
AdamB
Post by AdamB »
Thanks Laura - you learn something new everyday :)
for anyone else, the link for the 123 flex is at: http://www.themagictouch.co.uk/cutting/123flex.htm
I take it you have used this flex Laura? (if so, what's it like for application and washing etc compared to other flex's - I mainly use MDP Hot flex)
I might email them later for a sample.
Thanks again :)
hidehi
Post by hidehi »
Thanks Laura. I'd be interested to know about its washing too...
mrs maggot
we have found it good so far, med tac for weeding, so may not suit very detailed work, but amazingly fast and easy, good for layering, has a slightly different feel to their std flex, good price, washed a few new printed ones at home, and seem no different to any other flex. main dissadvantage - forgetting when pressing other flex and then spoiling the design as you pull the backing off too soon :mad:
hidehi
Post by hidehi »
Thanks Laura. I'm amazed at how much cheaper it is than their premium flex and also what I'm currently paying at mdp! Granted the minimum quantity is 5m, but even so, still cheaper...
mrs maggot
i buy it by the roll, so never look at PM prices - give them a call i am sure that Paul there will sort out some samples, they are also worth visiting if you are ever near luton/dunstable
bigj2552
Post by bigj2552 »
@ Laura - are those "purpose made teflon sheets" taliored to your actual press size ?...or are they just a standard size, fits all type of thing ?
how are they held onto the press ? some kind of tie / cord ?
and where to get em from ?...the usual suppliers that are most talked about on here i take it ?
cheers
johnny
There are different sizes to teflon. Standard sheet sizes are around A3 I think, but you can get larger sizes as well, e.g. 400mm x 600mm which covers the larger of the heat press platens.
