Re: can I use my existing printer?
Posted: 30 Jan 2010, 00:14
That's a very good idea. If you have two Epson 1400 and you end up with your main dye-sub one having problems (which usually happens in the middle of a very urgent order), you'll be able to switch over to your photo printer to complete the order if it becomes necessary. If you had two different printers, you wouldn't be able to do this. Your photo printer effectively becomes your backup printer. Nice thinking!TonyM wrote:Once again JSR, many thanks for a fantasic clear answer.
I have decided to purchase 2 Epson 1400. One for photo printing and one for sub printing.
When you're starting, I would say to get the CISS with ink from a reputable supplier of Artanium (Sawgrass) ink. When you buy the CISS with Artanium ink, it generally arrives "pre-primed" - that is with ink in the tubes and the cartridges.TonyM wrote:I have been looking at empty systems such as this.
http://cgi.ebay.co.uk/empty-ciss-cis-for-epson-1400-FOR-SUBLIMATION-INK-USE_W0QQitemZ250571010806QQcmdZViewItemQQptZBI_Toner?hash=item3a573232f6
What do you think about buying the sytem and ink as seperates?
Where would i but the ink as a seperate?
I see that the CISS system is £270 or therabouts, whereas the empty system is less than £25 and I keep seeing inks on e-bay all the time for part used inks etc.
Would it, in your opinion be worth purcasing an empty CISS system and try sourcing the ink from somewhere else. or just get the whole package in one?
It's usually a simple job of just putting the cartridges in the printer, securing the tubes and bottles as indicated in the instructions, and you're ready to go. If you buy the CISS empty from some third-party source, you'll have to get the ink through it on your own. If you run into trouble, will the CISS supplier help you out?
If you go for separates, you'll still need to get the ink. Buying the minimum quantity (125ml bottles at £61 each) will set you back £366 (inc. VAT) on top of the price of your CISS. However, if you buy the complete CISS with Artanium ink in one package - it'll cost about £310 (inc. VAT). That's £56 less, and no extra cost for the empty CISS, and no faffing about trying to get the ink through it.
Yes, there is a little less ink in a supplied CISS - 6x100ml instead of 6x125ml - however, using the cost price of 125ml being £61, then 6x100ml works out to £300 anyway. So, for £310 you're not being diddled out of paying more for the ink - in fact you could say that you're getting the CISS almost for free.
In addition to this, when you buy your filled CISS, you should be supplied with a CD which contains the correct colour correction profile for your printer and instructions of how to use it. If you buy an empty CISS and someone else's ink dregs off ebay, where will you get the profile from?
And, if you need any more convincing, if you do buy dregs of ink from ebay you need to ask two important questions. (1) Is it Artanium? There's no point mixing two or more varieties of dye-sub ink, because that will just lead to trouble. And if they say it's Artanium, do you trust them - or are they just saying what they think you want to hear? (2) How old is the ink? If someone is selling their dregs, they may have had it on their shelf for 1-2 years or even longer. If so, you don't want to touch it even if it's free!
OEM = Original Equipment Manufacturer. In this instance, "OEM ink" refers to ink manufactured by the same people who manufacture the printer. "OEM ink" for the Epson 1400 is made by Epson. "OEM ink" for a HP Officejet is made by HP. The phrase "OEM ink" is short-hand for "ink not made by any third-party manufacturer".TonyM wrote:Many thanks and i really do appreciate the totally professional and concise help that you have provided.
PS what does OEM represent?
Hope this helps.
